sugar babiestx_widebody wrote:This might be a stupid question but i wanted to know wat was the best sounding BOV on an RB20det, because i dont want to get one that sounds like a horn, just a nice clean loud sound?? heheheh!!! thanks for the input.
I have found a work around if you really want to run an open BOV, put the MAF on the Cold Pipe just before the intake throttle body... then you can run a BOV on the hot pipe or the cold pipe behind the MAF. Then just run a strait hard pipe intake into the turbo. The computer won’t have such a problem with the fluctuation in intake pressure when you use the turbo line. It won’t do that stalling thing every time your BOV goes off.Kansei240sx wrote:So you dont idle poorly and run rich.
Lol, dueling psssts??? That's probably going to be an Olympic sport someday. Like curling. Yeah. They'll cancel basketball since they can't fit it into the schedule and put psssting in instead.themadscientist wrote:The blitz super sound BOV on my Skyline(not the new one the one with the horn) is as loud as dump truck air brakes. No kidding, I once did dueling psssts with a Hino truck going down the road.
Sounds good.Kansei240sx wrote:My ARC blow off valve should be in soon and ill put up a video for you guys.
Agreed. Too bad they leak like crazy after 10PSI. I think mine is perma-screwed because of higher boost. If someone could replicate this sound with HKS SSQV functionality, I'd buy it right now...but they'd have to sell a reciruc. kit tooCarl H wrote:stock bypass valve sounds fking awesome, leave it be.however my hks race2 bov sounds like some one hit a duck at low boost pressures, and it gets worse as the boost gets cranked.......
as am i. i will be venting to the atmosphere tuned with a pfc.240sx2nr95 wrote:I'm gonna run Tial.
-Dan
