BOV ROUTEBACK QUESTION
ll SR SILVIA ll
Car: 1993 super hicus 240sx hatxhback SR20DET
dOES ANYBODY KNOW HOW TO MAKE A STOCK SR BLOW OFF ATMOSPHERICLY WITH OUT ANY IDLE PROBLEMS OR RICH STUMBLES IN BETWEEN SHIFTS WITHOUT A PIGGYBACK? I CAN FIND THIS INFO ANYWHERE ON THE INTERNET
SpeedRacer1
Car: 1990 240SX, G35
That would be tough to do because the stock SR recirc valve leaks air at idle unlike aftermarket BOV's.
ll SR SILVIA ll
WOULD A AFTERMARKET HOTPIE/ BOV MOUNTED WORK? OR STILL THE SAME THING WITH IDLING AND RICH STUMBLES?
jaboc03
Car: 92 Nissan 240SX coupe w/ sr20det
An aftermarket BOV might help. But not recircing the BOV on an engine that uses a MAFS will most likely always cause it to run rich in between shifts and can cause the idle issue. The computer is expecting that air that you are venting to be plumbed back into the intake.
jr_ss
Car: 95' S14
Get the HKS SSQV. It's a pull style BOV, so even under the highest boost levels it won't leak. It doesn't cause any idle issues, but not recirculating it will cause you to run rich inbetween shifts, like any BOV would. There is an adapter available so you can recirc if you want.
