Import_Ant »
https://forums.nicoclub.com/import-ant-u16968.html
Sat Jun 18, 2005 4:55 am
there should be two tubes on your intake, one for the PCV hose coming from your valve cover and other for BOV recirculation. if you only have one then I assume that is intended for the PCV hose. you can use any bung on your intake as long as the hose seals around it, if you don't attach your PCV hose you can add a small filter on the end of the PCV nipple on your valve cover or route it to a catch can (<-better of the two Imho)
the reason you need to recirculate your bov on a MAF based car is that the ECU adjusts your fuel trim based upon the air it meters coming past the MAF. so if you have a boost leak, or atmostpherically vented bov, the car will run PIG RICH when the air is escaping because the ECU has accounted for that air and assumed it made it past the throttle into the engine (which it didnt because it escaped) so the computer has added fuel to team up with the air to make *DA DUM* ideal AFR team, but the air doesn't make it there so the fuel is all alone and says "fine screw it I'll just try to burn by myself" which causes the engine to be overly rich, stumble, and sometimes die.
hope my goofy analogy helped but that is my input on your BOV ricirculation question. I am NOT recirculating my BOV, I just have to tap the throttle a few times if I go from heavy acceleration straight into neutral. You can run without recirculating, you just have to adjust your driving style. leave it in gear when you decelerate, keep an eye on the throttle if you get up past 2k rpm and just 'let off the gas' abruptly.
not sure what BOV you have but most have an adjustment to make it 'stiffer' (each car operates at different levels of vacuum at idle. to keep the BOV from leaking in a car that operates at a large amount of vacuum the bov needs to be stiffened up. take advantage of this setting if your bov has it to stiffen it as much as you can. it will make it less likely to open under minimal pressure and improve your city driveability as a result)
happy boosting-Aaron
