sultan »
https://forums.nicoclub.com/sultan-u295.html
Sat Apr 19, 2003 9:10 am
quote from another site:"The MAF sensor is used to determine the amount of air the engine is using so it can deliver the appropriate amount of fuel. In a car with a MAF sensor, when a BOV vents, air is escaping from a closed system. This air has already passed through the MAF sensor and has been measured, and the computer doesn't know that this air never made it to the engine. This will cause a brief rich mixture as the computer will still deliver the correct amount fuel dosage based on the amount of vented air."basically you're still bringing air in, it's measured by MAF (which is used to determine how much fuel to give), but a lot of it goes out the BOV and never reaches the engine, so the car gets too much gas.
