kouki munster »
https://forums.nicoclub.com/kouki-munster-u34314.html
Sun Oct 16, 2011 12:27 pm
The synapse is a just about the best bov on the market,(IMHO) since you have looked up the videos on youtube I won't take the time to type all the good things about it out.
I've been running one for the last 2 years and the only time that I get anything that remotely resembles compressor surge is while running down the interstate in 5th gear and I gradually roll out of the throttle after quickly passing a jack hole that cant stay in his own lane.
The only sound it makes is a simple whoosh, how loud it is depends on the pressure behind it. Although, I have noticed that above 20 psi is starts to have kind of a whistle/higher pitched whoosh.
The only down side is that with a maf car you will need to get the $20 fitting so you can run it open atmosphere or it needs to be recirculated.
