Ryoga4523 wrote:Right now I am just pushing a conservative 7psi, do you think that has anything to do with it?
The guy who put my engine together said that I should run it conservatively for about a week or so, then go back and see him to make sure everything is running properly, then he was going to raise the boost to 12psi.
FYI, 12psi will not destroy your turbo. Myself and two other friends of mine ran 12psi for a year and a half beating the **** out of our cars with no issues. I wouldn't go above 12psi though.Obviously though, you'll need more fuel if you crank boost to 12psi, so you'll need a stand alone or piggy back ECU to tune fuel and timing.It depends greatly on the tune, if you just crank boost and don't tune, you will break stuff, but probably not the turbo.
I even ran mine at 14psi for a little while until I realized the turbo wasn't efficient in that range and didn't give me much more power.
