Unless you're getting the 3-starter-motor electric supercharger from Knight, you DO NOT HAVE A SUPERCHARGER. Despite their vaunted claims, boat bilge fans just cannot affect the intake of an engine.Here's how to make it sensible to you: what kind of belt to real superchargers use? Roots blowers have a drive belt you could slice up and use on three 100-horsepower Harleys. Paxton and other centrifugal blowers use a pair of V-belts. A single V-belt can carry enough power to run your alternator with every accessory in the car turned on, and headlights, while also running the water pump, AC and power steering (although on most cars, this is divvied up amongst a few belts).Supercharging is NOT free power. It requires power -and not a trivial amount- to pump enough air for the engine to notice.The Knight supercharger uses THREE starter motors, and an extra battery -which it nearly depletes- for about twenty seconds of boost. There is no way you're going to get a supercharging effect through a 10- or 12-gauge wire as is used on the various fans they sell on eBay as being "electric superchargers". And no, you wouldn't have enough airflow to make a BOV noise. It'd make less foof than a fairey's fart.BOV noises aren't a goal. They're a circumstance of some supercharging arrangements. If your goal is the noise, here's the product for you:
http://www.takakaira.com/acces....html
