Let me clarify a few things up. I think I was not exact on my set up. I have a SS tubular header going into a T25 turbo. I have a 3" turbo down pipe going into a 3" down pipe; then continuing through a Apexi 3" exhaust system. I have read many forums about the boost creep. Using a 3" turbo down pipe does in fact create boost creep of 2.5 to 3 psi. Even with a stock turbo.
Darius wrote:The vacuum line on the BOV should not be connected to the intake pipe. It should be connected to a vacuum port on the INTAKE MANIFOLD.
And I need to clarify about that as well. I am using an S14 upper intake manifold, an S13 lower intake manifold and all the emissions have been removed including Charcoal canister filter, EGR blocked off etc. The BOV upper vacuum sorce is connected to the lower intake manifold itself by the nipple right after the throttle body. It is connected to the intake manifold and not the cold pipe.
The BOV does have 2 nipples. One on top and a smaller diameter nipple below it at an angle. The upper one is for the vaccum and the lower is one for pressure from what I have been told. Some other cars like the EVO or the Subaru turbo'd cars that utilize both. Hope this helps. I have tried other vacuum sources and nothing seems to change.
The compressor surge still comes back through the turbo. It does not make any sense. Any other options or thoughts?
