J-Spec Tuner wrote:your wastegate should open before the BOV, its probably just the way you have the vaccum hoses hooked up.
What pressure to you have the wastegate set to? At what pressure does the BOV open?
My BOV's hose is connected to a nipple on the IC piping right before the throttle body.
I don't know at what pressure my wastegate is set to and I couldn't see at what psi my BOV opened my boost gauge's light bulb wasn't working.
thanks for the reply
so then it isn't that my BOV is busted?
