thats the problem right there. the spring is too soft. tighten it and your engine will no longer die out when letting off of the gas. also run the vac hose for your bov straight to a TB nipple, dont T it off with anything else. also remember not to use the lowest nipple on the TB180sxmonster wrote:with the bov open to soft all the way
I agree that could be the case but its also a good possibility the spring is to soft, seeing as how you have it set the lowest it can go. i have had a couple of different bov's and i had your problem. i tightend the spring and the problem was solved. if that doesnt work then try recirculating it. btw what is the pro's and cons of having the bov on the coldpipe?srpowered240sx wrote:you need to recirculate or it will drop idle after hard revs.
word, i still think it will have an falling idle problem, but maybe not so much as to stall. try tightening it up and see how it performs.S13FASTBACKSR wrote:
thats not your speed sensor, thats your mass air flow telling your computer to dump a certain amount of fuel, then your bov letting the air out, and your injectors already firing extra fuel. now you have a very very rich condition while you are decelerating. it leads to stalling. you will have this problem until you change your deceleration settings with a safc, or recirculate your bov.180sxmonster wrote:i tightened the screw and the car doesnt stall out anymore but the engine still dies everyother time when i let off the throttle and hold the clutch.... but i guess thats because i dont have a 5 speed speed sensor yet... i think....causing the car to idle very low when coasting to a stop... but i guess ill have to get a speed sensor then ....
BTW thanks everyone for their inputs... you guys rock.... would of gotten loss.. thank a lot... turbo rocks....
