nissanfanatic »
https://forums.nicoclub.com/nissanfanatic-u21678.html
Tue Apr 05, 2005 11:49 am
Wheres the proof on that? Who says it best? And not everyone has access to a welder capable of welding aluminum. Plus if you screw up really bad on a piece of steel pipe, oh well. IF you screw up an intercooler. Dammit, out a couple hundred bucks. Not to mention, that doesn't look like a very optimal spot for recirculation.
IDK if anybody really knows where the best place to mount it is. But I know that I have no compressor surge with it mounted close to my TB. So it works the best for me. When I had it mounted closer to the turbo, even with the bottom port hooked up, I had compressor surge. So I'll just use this way.
To each his own.
