kingtal0n »
https://forums.nicoclub.com/kingtal0n-u29036.html
Mon Sep 07, 2009 5:13 am
put it on the hot side, as close to the turbo as possible. also run the vacuum line from the bov directly to the throttle body- if you T it off to something else, response is diminished. Use the correct size line too.
Reasoning: Your bypass valve is supposed to bypass unwanted pressure in the plumbing. If the bypass is on the cold side, then all of the high pressure from the turbo to the bypass has to flow through the intercooler to get out, which means it the venting will be slower, more gradual, not as sharp and not as quick. People will say this "keeps the air moving in the right direction"- however, air is always flowing into the engine, even at idle or after you let off and the throttle body shuts, the engine still breathes. The purpose of the bypass isnt to keep the engine breathing its to prevent COMPRESSOR SURGE. By placing the bov on the hot side:
the turbo gets a fast-as-possible response for relief of compressor surge
the release is more sharp, and faster, which on a maf car, is a large benefit (Due to the way the ECU cuts fuel) you will note that cars with bovs on the cold side, even a ssqv, will tend to backfire under light throttle conditions... because the ecu cuts the fuel but idle falls low enough for it to come back in with the bov still hanging open... and POP!
Air density at constant temp is related to pressure. whether the plumbing releases pressure on the cold side or hot side doesnt make a difference- the turbo still has to re-compress the column of air when you step on the gas. the air doesn't "keep moving" any more or less whichever side its on- the engine is always breathing, and unless you are shifting with the throttle body open, the column is going to lose its increased pressure ratio.
oh, i still put some bov on the cold side, just for looks though. they looks cool right there by the throttle body. And they are quieter, more subtle. And the vacuum line is shorter, which means it opens even easier. Yes it backfires unnecessarily and yes the compressor surges slightly more than it should but... LOL it still serves its purpose.
