bestint wrote:Blow Off Valve Placement
Blow off valve placement is not the most important thing to think about when building a turbo kit, however is does make a difference. It's the small differences that separate an event winner from the rest of the field.
The vast majority of people will tell you that you are supposed to place your blow off valve within a couple feet of your throttle body. I am here to tell you that this is not the best location for your blow off valve.
The best location for your blow off valve is going to be in between your turbo and intercooler, on the hot side.
Think about it. If you put the blow off valve on the cold side (after the intercooler), you are pushing hot air through your intercooler for nothing. This increases the speed at which your intercooler and motor become heat soaked.
By putting the blow off valve before, or even on the intercooler itself - you allow all of the hot compressed air to escape to atmosphere prior to passing through the intercooler. A blow off valve does the same thing no matter where you place it on the charge piping. Knowing this - it's only logical to put it in a place where it relieves hot air rather than cold air.
I cant believe someone revived a 2 yr old thread just to plagiarize what could very well be the worst article about bov placement, ever. So Im forced to chime in. While bov placement is mostly opinion and personal preference, that article shows some of the worst.
What is the reason for a bov again?? To be obnoxious and grab the attention of the people walking down the street or driving next to you?? No? Oh yea, to prevent compressor surge. And what is the best way to do that? Keep the air moving through the turbo in the same correct direction.
If you put your bov closer to the turbo, you will have more cool air rushing TOWARDS the turbo from the suddenly closed throttle body side than hot air from the turbo side. While the valve SHOULD let most negative flowing air out before pushing into the turbo, the idea of any airflow in this direction is generally not good for preventing compressor surge. Also speaking of your wasting intercooler use comment, this seems worse. You are cooling the air just for it to turn back around and let back out. To make matters worse, any air that didnt make its way through the bov before the throttle opened back up has to change direction once again to head back towards the motor, which cant help the already known lag problems between shifts with bovs.
So put it coldside like kouki munster. His setup has maybe 6" of possible reverse flow direction. This leaves everything pre bov to flow towards the engine, away from the turbo, which will keep your turbo spinning the correct direction between shifts, which may also reducing some lag. If you plan on recircing and dont want the hassle plumbing, put it hotside then. Thats where every intercooler kit with a built on flange ends up putting them anyway. These 2 reasons are exactly why mine is found hotside.
Best article found on the subject. He explains it better.
http://www.modified.com/tech/0....html
