it is greddy type s. when it was recirculated, it was better, but still there. tightening was the key. when removing the lower vacuum hose (the one that recieves the sig from before thr body) the valve was obviosly tight enough with out the extra pressure, and works much better. with the smaller nipple hooked up, the bov opens bigger and flows smoother and more air. but it leaks a bit at partial throttle. i have heard warnings of this before, but ignored them. anyway, i hope the problem doesnt come back.
so if the bov is chattering a little bit after only small boost then switching gears, is this a problem. it sounds like chicachicapssssssssssssssssssssssss. like my typing
