bov leak
probe2436
Car: 240sx
i did a boost leak test and found that my bov is leaking bad. it is leaking out of where it should blow off through but while under boost. I was wondering if anyone knew of a way to to fix it cheaply. if i need to buy another one i will. it is not a name brand but similar to a type rs bov. any help would be appreiated.
terry_240sx
Car: '93 240sx hatch
hmm if it's a knock off bov it could really be anything in the blow off valve that could have possibly been formed wrong :gotme
you could try getting a stiffer spring in there
I would just make a block off plate to keep there until i got another one tho
240man91
Car: 1991 nissan 240sx se hicas
just by a new one try a hks they work good i bought a type rs an it is adjustable an with it al the way tite it still leaked they are junk
terry_240sx
word. :dblthumb:
my hks ssqv works like a charm
240man91
i know right make sure it is a real hks one to not those cheap knock offs they leak to
neverlift
here goes a limb...
was boost applied to the bov source line?
I mean it needs pressure on top of the diaphragm to function.. when my freddy knock off fail I got turbo flutter which equals no or very low venting....
an inner tube is what I use to repair fail diaphragms with..
