maj Andres wrote:yes it is connected to the vaccum source along witht the disc in the line. Hooked up to a vacuum source right under the throttle body. Would it being on the cold pipe have anything to do with it? Thanks
Is that "with" or "without" a disc in the vacuum line? Are you talking about a plastic valve? Need more specific info on this.
Either way, that problem can occur with a vacuum/boost leak anywhere -- not just on that line alone.
And the BOV can be placed anywhere between the turbocharger and throttle body -- just as long as it can redirect compressed air when the TB snaps shut. I've seen them mounted on intercoolers even.
Modified by steeda763 at 11:59 PM 2/16/2009
