encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Fri Apr 04, 2003 1:56 pm
The BOV does not every need to be adjusted, unless you get a Greddy which can be adjusted for sound. You attach it between the intercooler and throttle body and the vacuum line goes to usually the intake manifold. When the throttle body closes the manifold has vacuum, which opens the BOV to vent excess air for reasons already mentioned about destroying the turbo and whatnot.
And the BOV (except the HKS unit, BEST BOV ever for this reason) doesn't hold tighter with pressure, it isn't designed like that, that's why some leak over a certain boost pressure, except the HK$ unit.
A BOV is a BOV for lower boost applications, my choice is a 1g Eclipse/Talon/laser BOV, $30 and works fine if you crush it.
