bout to buuy a inlet flange......and
erollinc
i need to know if i need the -4AN fitting or the -3AN fitting i bought the stuff from mc master ya know the DIY feed line and im not sure which inlet flange size i need can someone help me out with a quick answer?
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
well first none of the sticky(i made) is a an size. do you have a t3 t3/t4 t4 turbo?
basically what turbo do you have ?
Import_Ant
what turbo?
(stealth Edit) beat me to it warped! (/)
erollinc
z31 t3
sorry bout that.... yeah i was wondering what the deal with that was
Import_Ant
erollinc wrote:z31 t3
if you're referring to the fitting that attaches to the turbo the hose SHOULD be already threaded to 1/4 NPT threads
(if you used 5723K108 hose as listed in Warped's writeup)
if you're referring to the adapter that screws in place of the oil pressure sending unit it's a 1/8 bspt fitting.
but the complete part # listing according to Warped's Threadis as follows for a t3 turbo:
For T3 housing50785K219 4092K26 2712T4884092K11 5723K1085340K31
erollinc
ok i understand what you are saying ... sorry for being a retard..... but i need a flange for the turbo and i want to make sure i get the right size and threads..... could someone link me to tthe correct part cause i dont want to get the wrong inlet flange id appreciate it
and yes i have everything that was on warpeds list
Warped
if you have everything there then im not seeing what you need.btw i added this about 5 days ago its the restrictor you need if you didnt get it2712T488 .063 orfice size
Asia
Car: 240sx
I have the same setup as you, z31 turbo with mcmaster oil lines. I ordered a flange from http://www.jgstools.com/turbo/index2.html with a 1/8" npt TK027. It should work with the mcmaster lines.
Warped
now i see what you mean lol
erollinc
thanks alot asain you make life easy ... and yeah i got the resistor
