bout a 200sx ex 1987
noob2nissan-s12
Car: 1984 200sx turbo
got an other 87 s-12 ex model need new rear.
when i shift gears there is a big clank coming from the rear end i checked it the best i could with out a lift..
1. The driver rear wheel needs a bearing rim moves back and fort. 2. big clank when shifting gears. (a) possibilities the shocks may be wore out. (b) the driveshaft may be loose. 3. changed the clutch mastercylinder.
Q: Do anyone know of a non independent rear suspention set up on any 200sx notchback or hatchback that has been done? let me know...
the other s-12 is not getting the ca18 (et) engine the body is more messed up than anything, it would cost more to fix the rust than to make it run.. so its going to have a transplant and used at the track.
getting a 302 and and making it into a 404 can you say ssssleeepaa. let me know if anyone can help...
