Bouncy ride after Coilover install HELP!!!
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
i installed a set of coilovers on my s13 hatch and the ride is just absolutely terrible...its bouncy even if i go over a small bump and over large ones my a** comes off the seat at times..i know coilovers usually have a rougher ride but im sure this is not normal and i need it fixed asap!could it be the preload is wrong? should the height be set the same all the way round? whats the deal and how can i fix this?PLEASE HELP ASAP.....S**t needs to be fixed...Thanks guys!
94_240sx
Car: 94_240SX
What brand, new or used, adjustable? We need more info. You need something like Megan, KTS or Stance for decent ride quality. Most of coilovers below those don't ride good.
chrismo240sx
Car: 92 240sx HB
S13 Blacktop
yea theyre used NEX but basically brand new....i did some research and sure enough they arent the greatest brand out there lol, i fixed the problem a little bit.....they were at the highest setting so i lowered the car a little more so that the springs were actually doing something instead of just being stiff as anything....also had some preload so we lowered that down as well
any other advice would be good, i still gotta do the right rear but couldnt since the locks were barely moving anymore and my hands were numb from the cold.
94_240sx
Car: 94_240SX
Okay, just wear rubber gloves when you turn the coilover body. It's easier with those.
silnismo
BUY A QUALITY COILOVER
problem fixed!
watch out nex's are blow happy
phanatikz32
Car: 1991 NA to TT z32 biatch!
silnismo wrote:BUY A QUALITY COILOVER
problem fixed!
unless you have an EG hatch or an integra dont buy NEX coils, you should have bought megans.
Cameron
Car: a 240
whats the spring rates?
are they dampening adj?
smocan
well if you have proper preload and the dampening on the softest setting... i dont think it can get any better...
try 55+ series tires?? haha
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if it's too stiff get lower spring rates, if it bounces like a bouncy ball your shocks are blown and your spring rates are too low and or not enough preload
