Bobby12many »
https://forums.nicoclub.com/bobby12many-u7612.html
Mon Apr 12, 2004 9:47 am
I recently purchased an S13 dohc and am looking to fix a small and silly idle problem I am having. When the car Idles, it usually sits between 500 - 900RPM, but it fluctuates sometimes, quite quickly within that range. After sitting for a while, the idle seems to smoth out, but after revving the motor, or putting in the clutch while moving, the chance of the idle becoming bouncy increases dramatically. Along with the idle issue, I am feeling a tad bit of lumpiness to the motor's acceleration when below 3krpms.
I removed the AIV system completely today, and that took care of alot of my low RPM issues, but those listed above are still there, although not quite as bad.
I plan on checking the PCVs and Coolant Temp Sender today....
Any ideas?
