skiski329 »
https://forums.nicoclub.com/skiski329-u81892.html
Mon Jan 06, 2014 7:15 pm
So this has been happening for a while, but i haven't been able to catch it on camera because it doesn't always happen.
It only happens on start up and usually doesn't happen more than 3 times.
When it does happen, I fire it up and right away the rpm goes up, then dips down to normal rpm, jumps up 200 to 300 rpm, then falls back down. that happens 3 times within about a second or two, then it goes back to normal.
I've been looking for a technical name for the problem, cause, and solution. Any ideas?
so far i'm leaning toward vacuum issue and maybe that's what's throwing my evap code that i keep on clearing (cuz i haven't found the cause yet)
Let me know if any pictures or video (i can keep trying to get it, but either my camera is too late, or i forget to pull it out).
Thanks!
