He said a 98... Does your kit accept different bulb types, or is it one of those were you have to the get the bulbs from the company? But from the sounds of it, either way you're going to need h4 bulbs as i don't think h7 will secure properly... I say sell off the kit and just buy another one, as buying bulbs are probably going to run u the same amount as the kit anyhow.superuber wrote:You still did not tell us the year. You can get the right bulb for your application and they should wire in to your hid set up. Also, you should be running a relay or relays with hid's so the bulbs light correctly. Are these oe or aftermarket plug and play. Of course if you know that little maybe you should have a pro do it!
