seldomseen »
https://forums.nicoclub.com/seldomseen-u87252.html
Sun Jun 08, 2014 9:22 am
The factory specs of the 18" OEM wheels are as follows: 18x7.5 (45mm) offset with 235/45/18 tires. The setup you purchased for your daughter's coupe is more "aggressive" than the OEM specs. The wheels you bought are .5" wider, and the offset is 10MM more negative (protrudes from fender) and the tires are 10MM thicker. However, the setup should not result in any sort of rubbing under normal driving conditions--- if I understand your post correctly.
If you want to ensure the coupe will not experience any rubbing on 18" wheels, the easiest and safest method is to simply ensure that the aftermarket wheels you purchase match the 18" OEM specs. When a person decides to upsize wheels they have to make adjustments to address factors such as wheel size, width, offset, tire size, and ride height to ensure proper fittment. You simply cannot purchase what fits a wheel(s), and/or what wheel will mount to a car and expect the same look across the board.
