Quark »
https://forums.nicoclub.com/quark-u13740.html
Sat Feb 21, 2004 3:53 pm
hey guys, I just bought a 240sx and found this forum. Was wondering if someone could help me out with some technical issues with my car.
First.
its a 1990 240sx coupe. converted to 5-speed
1. My clutch chatters sometimes if I ride it too long from stand still to 1st gear, also when rolling on 1st gear, the car tends to rock back and forth a little. Now I was under my car the other day and noticed that the transimission crossmember, the one under the shifter is all mangled up and has only 3 of the 4 bolts installed, the 4th hole is so missaligned that you cant fit the bolt through. I heard that this crossmember is different from automatic and manual. So im thinking its putting some strees on the transmission?
2. my water temp gauge on my dash, begins to drop to cold when I am around 4k or more RPM's I dont get it, something loose?
3. my tension rod bushing on the right side cracked and leaking, could this cause my car to pull to the right? ive checked tire pressure and camber, it all looks ok.
if someone could help me out, i really appreciated it.thanks
