Ya!
Welcome to the club. It is hard not to drive it!
If you are having problems with sitting up high, or near the windshield, the seats lower drastically with the buttons on the left hand side for driver and right side for passenger. Made for a more comfortable drive for myself.
You also have more cup holders then you will ever use. If any thing gets in the center console cup holders you can remove the inner piece. Just lift up on the back of it. It is seperate from the rest of the holder itself. You don't have to use a key anytime on the car. Just keep the keys fob with you, or near you. There is also a door lock on your gas door. The car has to be unlocked for it to be unlocked.
Did you get a cargo net in the trunk? If not, I know where to get one from Nissan in Texas for $31 dollars + shipping. It is the same as a 370z's.
Sport model eh? So big brakes?!!
Your sport mode is 2 modes. You will notice if the car is in drive, and you push the stick over to sport mode the dash will display 'DS' mode. If you punch the gas the car will act like it is in Drive but the gears will go up in RPMs to get you more juice! If you push the stick over into + and -, displaying DS mode and push the stick up once, this puts the car into Manual mode. Manual mode means you have to use the stick to shift gears, and you can redline the car. When you redline the car it will not shift. However, if the car is in DS mode, it will shift, not manaul mode.
Pulling on the padel shifters around the steering wheel will put the car into Manual mode. It will also not shift then. If the car doesn't see you are playing around enough in either of these modes it will go back to regular D. Your A/C will also adjust for foot and head temperature. If you leave your lights on AUTO on your left steering column stick, the lights will cut off and on when they feel like it, especially if you go under shady trees for a second. And if you think its a race car, you are only experiencing a ECU controlled car which only allows certain HP in certain gears such as 1st being 182 max hp. But you are putting anywhere between 285-300hp to the wheels.
Oh and those Wheels are slotted to fit your big brakes, and they are $450 from a website called
http://www.allfactorywheels.com/
But i'm sure you read the Owners Manual too, so.
Oh and the sunroof adjusts 3 different ways, and you can stop it halfway during opening.
And the car looks BadAss with the sunroof up! hahahah.
