bought kyb gr2 and tein s type and i need help on installation
mattscar
Car: 1989 240sx, 1992 Miata
i searched and it only gave me "wtb or for sale things" this is not what im looking for. i purchased KYB GR2s and Tein S springs. and i need help on installation.
thanks
mattscar
oh yea i have a 1992 S13 FB.
btw.
teddy
Car: Saab Turbo and MR2
what exactly do you need help with?
mattscar
installing it myself. or should i have a mechanic do it?
240sxjeff
Car: nissan 240sx zenki version
Its really not that hard, but I don't know how mechanically inclined you are.
You need spring compressors (rent them at autozone), a ratchet or air gun, I think 17mm 14mm and 12mm sockets, and a 17mm box wrench. I beleive that all you need. Oh and a jack and some jack stands and maybe like 2-6 hours of your time depending on how many problems you run into
mattscar
are spring compresors hard to use?
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
if you arent clumsy and a compelte ****tard, they are easy
Ezzo
A spring compressor isnt hard to use but someone has to say it, You can really **** yourself up with a spring compressor if youve never used one before. I would suggest having someone around with some suspension tech experience with you if any of your friends or family are inclined. If your careful and take your time you should be fine though, so don't let that scare you off. Other alternative is to bring the spring and shock setup to your mechanic, local dirt bike shop, or chained break and suspsnsion shop. They should all have the proper equiptment to mount the springs for you. Oh yeah a FSM would be of great help to you with it too, there should be one floating around here in PDF format. someone had it in there sig for a wile
mattscar
will the local dirt bike shop mount the spring and the shock for me?so all i ave to so then is yo install it?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
as for the local shop here
that is correct
c32c7
Car: Kouki S14
**** the spring compressor, you dont need it, just use a towel to catch the parts and let that **** shoot out.
i dont trust those little clamp spring compressors, if you're gonna use one, use a big floor stand model.
and an impact gun isn't necessary, just helps if you're lazy
x8ver
I would not recommend that towel technique. I have just done a suspension with the spring compressors and if your not careful youll take your hand off. Put on the compressor real tight and dont use fingers to take off bolts cus youll hurt yourself. I had found this that helped out. its on a 95 but same process.
http://importnut.net/240springstrut.htm
go slow be careful.
mattscar
thanks for the help, ill just ave my auto shop teacer help me mount the shock and spring for free but i have another question, the parts i need to reuse is the SHOCK MOUNT INSULATOR and the dust boot correct?
x8ver
Yeah the top pieces they should know what they need. Even though you should replace with new parts that is what is recommended. Especially if your front strut bearings dont spin properly.
mattscar
is thier anything i should mark when i take off the shock?
240sxjeff
I think your looking too hard into this, its really simple once you actually see it in person.If my mechanically challenged 16 year old brother can throw on lowering springs I'm preetty sure you wont have any problems
mattscar
ya thanks for the wisdom i just dont want to mess anything up, lol !
240sxjeff
I highly doubt you will mess anything up but your knuckles
