offtheline »
https://forums.nicoclub.com/offtheline-u5954.html
Wed Jul 30, 2003 11:42 am
I also bought mine from tirerack.com. However, I am not entirely sure that I was sent the correct boots. That being said, I was sent the correct part numbers. When I put the boots on the rear struts, the boot was so tightly stretched that it actually slipped down over stopper and basically allowed my car to ride without the stops on about an inch and a half of spring play. I ended up keeping them attached, but allowing them to slip down under the stop and I used the stock bump stops which have a metal plate butting up against the stopper. Has anyone else had a problem with the rear boots being too short?
