htsource wrote:Thank you, you confirmed my thinking in regards to the hood.
I did play with the backup camera again and it looks like unless the car is in reverse, the camera view is blacked out if I switch to it during driving for example? Any way to defect that?
I may now consider doing the entire floor but taking everything apart seems a lot of work
Thank you.
In the 8120 menu, under either the user interface menu or the A/V interface menu (I believe) there's a screen where it allows you to select the option for holding the nav button longer than 2 seconds
1 option is to show the rear view camera
the other option is to turn the screen off...
so right now, when I hold my Nav button (2nd from the right) for longer than 2 seconds, the rear view camera kicks in and I can just drive with my rear view camera on, until I hit the button again.... man I should start charging for this info.... j/k
