v6 »
https://forums.nicoclub.com/v6-u77197.html
Thu Sep 27, 2007 12:35 pm
I bought an HID bi-xenon 9007 conversion kit (single bulb with high and low operations) for the 2005 nissan pathfinder se that i have. I installed it and the high beams goes on instead of the low beams. To solve the high beam problem I took out the fuses from the high beam sockets. Well I have low beams operational and when i use the high beams the lights goes off.
These are my trial and errors:1. I then put back the fuses for the high beams, I turn them on and the high beams goes on instead of the low beams. I even set my headlights to high beams, but still the same glare.
2. I even reinstall and reconnect the kit, still the same glare.
3. I tried inverting the wires (+, -, and white wire) that plugs in the orginal socket for the headlights (factory headlight socket). Still the same.
Currently I have the low beams functioning when i turn on my headlights, but my high beams are not. Do I need to put the positive connecter for the HID kit to the negative connecter of the battery? I would try that but it might damage the kit. If anyone knows please reply. I would appreciate it. Thank you.
