Bought head unit. Wont turn on, sort of.
Post all your Nissan electronics, car audio and stereo questions here!
I bought a CD/MP3 head unit for my Maxima (with Bose) and a Nissan wiring harness. I ran new speakers wires directly to 6x9s in the back, skipping the Bose amps. The problem is, the unit wont turn on. It comes on briefly when I touch the blue "amp turn on" wire to the metal part of the head unit, but thats as far as I can get.
My antenna is not connected because I do not have an adapter. I dont listen to local radio anyway. Do I have to connect the antenna to make the stereo come on?
Help, please!
PoorManQ45
Can you take a picture please? Try just hooking up the power and ground. DOn't bother with the speaker wires at first. Do that and see if you can get it to turn on. If you can, then continue the install. If you can't, then either, a: You're tai and need to make me some curry, or b: you're american and need to make me some fried chicken
You do not NEED an antenna to have the stereo come on.
I found out that you need to have the antenna connected for the stereo to come on. Its used as a ground loop. Picked up an antenna adapter for $19. Life without Bose feels so good.
zippitta
Car: 1990 240SX HB
Yea I was just about to say that most newer cars use the antenna as the ground
PoorManQ45
Hmm, I've never seen a HU that needed an antenna to turn on.
Usually there is a screw on the back of the HU chassis that's used for ground
kill1get1free
Car: 90 240sx, 92 240sx (parts), 93 hardbody (parts),94 hardbody, 2003 Sentra se-r spec v, 2015 Quest Platinum.
All of my HU's have used the antenna as a ground and 19 bucks for the adaptor sounds expensive but thats just the diference between wal-marts i guess. Got mine for $10.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
Actually they are supposed to ground through the ISO brackets when you bolt them to the sides of the radio with machine screws. Yes the antenna is grounded or you wouldn't receive any AM signal.
You should always use a separate ground wire when wiring a Nissan that does't have one in the harness. Unless you are using the factory unit.
Sorry, I was sick all last week didn't read this in time to help. I did read your post aobut your trip across the country and gettin stuck at motels.Funny stuff.
