M374llic4 »
https://forums.nicoclub.com/m374llic4-u35918.html
Sat Jun 10, 2006 7:30 am
Hey guys, I finally got a CA : D, heres what it came with
CA18DET Block and Head (needs rebuilt, spun bearing in #3)Intake manifoldExhaust manifold2- T25 turbo's (needs rebuilt)Cam CoversWater PumpOil pan (needs replaced)Coil PacksStarterCrank Angle sensorInjectors5 sp. ECUMegan racing down pipe
I for some reason didnt get the coil packs, because I guess i forgot they were included and he didnt mention that, but its all good, I emailed him about it. : )
I know I need wireharness, coilpacks, ignitor, but what else do I need besides like, belts and all that, also will a KAE transmission bolt up, or do i need a bell housing like an SR does?
What parts from the usdm CA can I get? I will take pics of what I have to show you guys, and you can make suggestions.
I need a rebuild kit also for both the engine and turbo, I wanted to put alot of money in to it, go for 400hp, but my KAE is messing up good, so I might need this sooner.
I plan on possably, t3/t4, bigger injectors, arp head studs, megasquirt (after some research on it) 255 pump. But just want to get her up and running asap.
Thanks guys ^_^
