zer0faith wrote:i read that i could swap out the stock injectors and fuel filter for z32 ones. would I have to modify anything to do that?
The heater hoses are the ones that run from the radiator to the engine right? I also read that my koyorad radiator and apc hoses can hook up to the redtop without much work. Is that correct?
I read your write up Posi. It is very informative, thank you. I'll be using it as my guide!
Modified by zer0faith at 4:02 PM 2/9/2009
You can swap out the Z32 fuel filter but I'm not sure about the injectors. Is it a USDM Koyo rad, if so, you just have to reroute the top hose across to the other side no problem.
