eZg001 wrote:so.........did you make it to the dyno yesterday?
Barely, I spent all of Friday night finishing the plenum. Still wasn't completely done, but all of it was improved over it's original self.
When I woke up, I remembered that I needed to change my oil. Just finished break-in and I was at the recommended oil change interval. So I headed over to Walmart for some M1 and a filter.
Got back...blah...blah...blah and I had 1.5 hr to get there. Google maps said 1hr 21 mins in perfect traffic (up to 3:10 for traffic). I ran into SOOO many traffic "blocks" it wasn't funny. I was swerving through traffic the whole time trying to maintain 75-80.
Got there at 12:38 for a 12:40 dyno. Luckily they stopped for lunch. I let her cool down a little and they did the baseline. 279 peak hp for the first run, then they sprayed down my plenum because I was getting knock. 283 peak for the second pull. Tq peaked at 250, but the curve looked horrible (interesting compared to the dyno dynamics which gave me a fairly even curve).
I ended up having to make and install an FX35 grounding kit right after my first run and had just shy of 2 hours to swap plenums. In the process, I bent my fuel line (metal on). Lost a plenum bolt. Lost a little flesh. and realized that WE ALL need to invest in an oil catch can. Damn was that messy!
The results for the second dyno are hard to understand. Peak HP went up after a couple of runs. The graph showed me loosing some hp in the mid range, but also picking up huge tq where I had deep valleys from the first run.
I think the lower plenum needs more work (got some advice from another guy there), plus I need to go with a smaller spacer. The blox is hurting more than it's helping I BELIEVE.
I didn't have the money, but I'm thinking about getting the Uprev Osiris. It's like the Cobb, but allows for custom maps NOW (not when cobb feels like it). And it stores the maps in the ECU, not on a piggy back system.
Normal price $650 with tunes. Yesterday's price $500 with tunes
I'm asking for it for Xmax. lol
I'll scan and and post up the dyno sheets later. Got to get to breakfast.
