bigb00st »
https://forums.nicoclub.com/bigb00st-u121282.html
Mon Dec 01, 2008 2:20 pm
It's a 5AT unfortunately I didn't have a wide selection due to my current financial situation.
I plan on taking it back to the dealership to have some all of the things I've found wrong with it that are covered under warranty. But heres a quick breakdown.
The good. It only has 53,000 which for an 04 is pretty low, black leather, cross drilled & slotted rotors on all four corners ( is that stock? I hear of the 04's having brembo's, but it dosn't say brembo anywhere on the caliper so I'm not too sure) Has those EBC Green pads as well. Has newer generation G35 18's on it too.
The bad. Has a small oil leak near the number 6 cylinder which drips down onto the exhaust manifold heatshield causing it to smoke very slightly when it sits still when your moving you can't tell that will be the first addressed at the dealer. The audio cuts out on ALL left side speakers when going over bumps and such. The sunroof won't go all the way back at one time, I have to hit it, and either hold it, or let off, hit it let off hit it.
Apparently the 04's have an ugly interior ? I don't know the difference obviously, the only thing I hate about it is the volume and track change is on the passanger side!
But I'm not going to let any of that stuff discourage me, I'm a huge 1st gen mistu/dsm guy which in turn has made me a decent mechanic and I look forward to broadening my knowledge to include nissan.
Any common issues these cars run into that I should be aware of? I plan on doing a nice fluid change within the next few days. Already put 3 coats of Zaino on it and it looks gorgeous. Will try to have pics up soon!
