You can. But you'd need a much higher octane than anything the pump will provide you. The increased compression ratio will make the air fuel mixture more likely to auto ignite on the compression stroke since compressed air and/or fuel mixtures' temperature is proportional to the pressure of the system, Boyle's Law in short. Basically higher compression ratio makes the mixture hotter and easier to ignite without spark, making the engine more likely to knock. Couple that with Boyle's Law in application with the higher compression of your intake air which will make you intake temps already hotter than ideal. You'll have to combat that effect with higher octanes which resist compression ignition. Basically I'm pretty sure you'll knock on pump gas.DJ Cool Breeze wrote:
So to recap ....
1) Can i run like 20-25lbs of boost with a 9.5:1 compression?
If you have a spot on tune and a higher octane you should be fine. So for a race car you are fine and dandy. For a street car, not so much.DJ Cool Breeze wrote:2) Will higher compression make my car less reliable? or more likely to detonate?
Remember we're talking millimeters here. The thickest head gaskets are about as thick as a credit card. I think the timing chain has enough slack in it to compensate for that but I'll try to verify that and get back to you,DJ Cool Breeze wrote:Redtop- If i were to get a thicker headgasket would the length of the timing chain be a problem? wouldnt it need to be longer? im just thinking since the distance would be greater due to the bigger gap between the head and block?
Thanks guys.
I think he said 100 octane to boost to 20-22psi and 110 to boost to 24 IIRC. i need to verify that in my emails before it is gospel.DJ Cool Breeze wrote:Good stuff to know Karmakaze, and red top.
I have 2 questions for both of you:
Karma- So what kind of octane would you need if you were to up the boost? like 100 octane?
And can i buy a knock sensor? do they make such a device? and how much would it be ?
Thanks guys.
