Bottom end set up
Slipstream
Car: '94 Sonoma, '90 300zx n/a
What components have you all gone with for turboing the KA? I'm rebuilding mine from scratch and wondering what to use? Money is an issue somewhat, but I'm gonna get quality parts. Also, what compression ratio should I look for? It will probably be run NA for a little while before turboing, so I'm looking for a ratio that would work best for both.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
budget? ams has some good prices on rods and pistons(8.8)
DammitBobby
Car: S13 91 KA24DET
+1 AMS
Chris@AMS
Car: 91 Nissan 240sx
Yeahhhhhh, we do. Check it out here:http://www.amsperformance.com/...th=24
Let us know if you have any questions.
lrb_2000
Car: '91 Nissan KA-T hatch
AMS FTW!!!
haha..
I'm usuing AMS/Turbo 240 rods, Supertech 9:1 Pistons w/ fullseal rings, Clevite main/rod bearings, ARP rod bolts, and main studs. .. everything except the pistons I got from AMS.
I'm sure 9:1 will be fine for N/A withough losing too much power, that's what i'm doing for the break in.
GTR PrYdE
Chris@AMS wrote:Yeahhhhhh, we do. Check it out here:http://www.amsperformance.com/...th=24
Now- if AMS can just finish their turbo kit they would be our one stop KA-T shop!but seriously- 718hp KA? Awesome stuff.
PapaSmurf2k3
Site Admin
what are your hp goals? you might not need rods.http://www.deatschwerks.com/ should be your injector guys.
nissanfanatic
Car: 1992 Nissan 240sx SE
I'm using only the best...
Slipstream
My goal was gonna be modest, around 300hp. But I didn't have time to finish yanking out the KA in time for school cause I kept getting called into work, so I took my SR block in to start on. Unfortunately, they only let us work on one motor at a time. The KA will either have to go bye-bye or wait until the spring quarter.
GTR PrYdE
nissanfanatic wrote:I'm using only the best...
Indeed. I've modeled my KA-T plans around your setup. Awesome work.
GTR PrYdE
Slipstream wrote:My goal was gonna be modest, around 300hp. But I didn't have time to finish yanking out the KA in time for school cause I kept getting called into work, so I took my SR block in to start on. Unfortunately, they only let us work on one motor at a time. The KA will either have to go bye-bye or wait until the spring quarter.
If 300 is all ur gonna go for- a stock rebuild should handle that fine. If you can- go just pistons- and a cometic headgasket- as added insurrance.
nissanfanatic
Nah.. Leave it alone for 300whp. No point in fixing something that isn't broken. More than likely, the cometic will give you more trouble than its worth.
ARP head studs with stock head gasket is the most simple yet effective setup... It has held 31psi on my setup for a full 4th gear pull..
GTR PrYdE
I see- but I think he is already rebuilding the block. Which in most cases- why not go ahead and spend the extra if your plans might go there? And I think you have a freak engine. 31psi with just headstuds is ridiculous.
nissanfanatic
Because the Cometic is unnecessary for anything sub 550-600whp on an efficient setup..
KATwo40
Car: 1993 240sx KA-T
^^^ Agreed.
