ganma_ca »
https://forums.nicoclub.com/ganma-ca-u122380.html
Sat Feb 07, 2009 4:03 am
I'm semi planning to rebuild my bottom end. However if I do, I really only want to do the bare minimum. (I know that kinda sounds bad but I'm not Mr. Bill gates). I plan on getting it bored out .20 over and getting a set of wiscos for it.(i will have the rods checked, while having the pistons installed on them, as I do not have a piston heater). I want to replace the rod and main bearings as well. I don't want to do anything with the crank but make sure it's in spec. I remember it costing $1,400 to rebuild my CA18ET bottom end. And I want to try to keep it under $1,000 this time so I figure the following. $25 a hole to bore it $100$500 for the piston kit from wisco$100 for rod/main bearings$100 in other labor(? don't know how much it costs for swapping pistons)$120 for Greddy Timing Belt$150 for oil pump(may/may not replace right off the bat)$120 Misc gaskets/seals/bearingsSo $1290/$1140 - Oil pumpOr not mess w/it lol Free:) I just want to know in every ones experiences who have left their block alone maybe only changing the timing belt/oil pump/water pump/ maybe running on 1 bar with a few mods and the engine supposedly only have 67,XXX miles on it if holds up really well? I mean it would be nice to save the money and spend it on doing a more complete rebuild down the road instead of only being able to afford doing a partial one right now? (and I mean as long as everything else checks out with it as well).On the funny side of things I called a local shop who I had never dealt with before and asked them this: If I brought you guys an empty block and all my parts ready to go back in (pistons/rods/crank/bearings/girdle etc) How much would you charge? (only because this would be the second time I've ever done internals on an engine and I don't want to f@#$ it up, not to mention I'd rather leave it to someone that rebuilds engines every day) and he said $1,000 lmao I just kinda laughed a little and hung up. Technically I can do it myself, but it would be nice to have someone with a sh*t ton more of experience to go over it before I would throw the oil pan back on. Anyone know what other methods can be used to separate the ca pistons from the rods? Kinda funny but I thought of putting a pan on the stove turning it to 185* and putting the piston in there and pushing the pins out. Don't know if thats a good idea or not??? Thanks anyone for feedback*P.S. Or should I just find someone with a good bottom end (no dirty remarks!) on here???? (if anyone has one)
