HighwayStar22 »
https://forums.nicoclub.com/highwaystar22-u7637.html
Tue Mar 24, 2009 6:10 am
I started to finish the full breakdown of the extra CA I got from Ed in VA back in Feb. Motor had serious water intrusion in 2, 3, and 4 when I got the head off to have a look see the first time I got it home to FL.
The cams have a decent amount of flash rust, but that will come off when I polish those like the last ones from the motor I just finished building.
Pistons + walls had heavy amounts of rust build up. I didn't want to break down the bottom end and risk heavily scoring a wall up with the buildup in rust. I've done that once, and now I have a spare block that needs a huge overbore, or needs to be sleeved. I soaked each cylinder in Marvel Mystery Oil. I've done this before on smaller engines that have seized (Go-ped, go-karts, lawnmower motors). I let it sit for a bit and slowy began to break down the rust build up by hand and with a flat tip screwdriver. Got the big stuff out, and then let it sit for a month more.... mainly cause I was busy doing randomness.
This leads me where I am now. Almost all of the rust buildup had been dissolved and I cleaned the rest out, making way to pull the rest of the bottom end apart. I got stuck on the crank sprocket. I managed to pry the other one off on the previous motor, but this one will not budge. I torched it for a while to see if the heat would get it to loosen, and it won't. I took a pause and continued breaking the rest of the motor down. Girdle, main caps, rear main, pistons and rods; it's all out of the block. I unbolted all the bolts from the front oil pump and pryed it away from the block to where I can see space inbetween the two. The rear of the crank lifts out a bit, but it WILL NOT move in the front.
What am I missing guys? Shouldn't it all come out and I can cut the sprocket off with a cutoff wheel? I need this crank out so I can build this as my spare race motor. Please lemme know. This is only my second full tear down and I can't remember what I did when I built my last one. Thank you.
