DawgMode wrote:Nissan OEM bearings...the best u can go with
AMEN!
You can get the thickness you need with the different OEM bearings available. The aftermarket guys only offer one thickness. Some poeple dont give a rats ***, and use the one thickness, even though it may not be the correct one to use.... then they pull then engine 2 months later due to a spun bearing.If you do it correctly, you would have the block and caps machined and the crank machined/polished to match the aftermarket bearings that your are using.
OEM bearings are great, there is no real good reason not to use them. As long as you keep your engine oiled, they will not fail.
ALSO, the COLOR mentioned above corresponds with a GRADE, nissan paints the different bearings with a color when they manufacture them, that way they can tell them apart. I forgot what color = what code, but the info is out there.
and also, IF YOU DONT KNOW WHAT THICKNESS BEARINGS TO GET....YOU SHOULD NOT BE REBUILDING YOUR ENGINE!!!Bearings require precise tolerances within the fraction of a thousandth. You dont just plunk in new bearings because some dude on a forum told you to use king bearings. Follow the instructions in the FSM religiously.
THIS IS ALL CLEARLY OUTLINED IN THE FSM, IF YOU DONT HAVE AN FSM, THEN YOU REALLY SHOULD -NOT- BE REBUILDING YOUR ENGINE.
good luck!
