Bottle feeding Baby KA
dr1ftr
Car: 1993 Nissan 240sx
Hey i've been looking for some Nos setups for a quick hp fix.. I've decided to get a Wet System.. do they make kits specifically for the KA or do I just get any 4 cyl kit?
Oh i'm thinking about starting off with either a 50 or 75 shot since i'd have the extra goodies..
This would be my setup with everything (including NOS)
2.25inch catback exhaustApex i N-1 MufflerHotshot HeaderNGK 8mm plug wiresNGK colder plugs.. i guess stage 7 Fidanza flywheelACT clutchMSD Ignition BoxMSD BlasterSS coilWalbro 255lph fuel pump
Feel free to add or take away from the parts list, I appreciate everyone's help. Thanks fellers.. drift on
All_Motor_KA
Car: 1989 240sx SE
With the drift on comment, I must add what do ya want the car for? Drifting or staight line raceing? Do you have an LSD and/or suspension? You might wanna think about these before you go with nitrous. But if you do go with nitrous a universal kit should do fine. Just read up before you do anything.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
With a 75 shot you can run stock everything.
Other goodies will help a little, intake headers and exhaust will make the engine breath a little better, the ignition upgrade is a good idea, but colder plugs are not needed.Fuel pump is also a good idea, but not a must.
All_Motor_KA
Car: 1989 240sx SE
...I'm sure he can run even 100 shot with the 255 fuel pump safelly.
dr1ftr
Sorry guys.. i have KYB AGX adjustable struts.. Eilbach 2inch lowering springs and Cross drilled and slotted rotors all around for suspension.. Thanks for the replies though. Oh and more just straight line racing.. I cant drift.. lol i hit too many things
frapjap
'07 Subaru Legacy
If you want a nitrous kit, I've got one with EVERYTHING you'll need, you wont even need to drill a hole into the intake piping, I'll send you mine!
Anyway, its a Zex dry kit, single fogger good for 50-75-100 shots. Small compact bottle, WOT activitation and shutoff. Gimme a heads up if you're interested.
Redline240
Car: 95 240sx
Doesn't seem like many people are really into puttin the KA on the bottle...i've been toying with the idea for the past year and i finially picked up a used dry setup. I'm gonna run a 75 shot on my stock engine, but i'm gonna slowly upgrade with some of the addons like window switches. Eventually i'd like to pick up 4 nozzels, fuel selinoid, and lines to run a direct port setup. Bypass the stock fuel system all together and run a small fuel cell and i already got a 255lph inline pump...
I'd like to see how good i can do in the quarter without internals...
What type of plugs is it that you can't run with nitrous? Iridium or Platnum? I might just run copper anyway since nitrous seems to a ***** on plugs...
Redline
dr1ftr
So i should be fine to run a 100shot with the upgraded fuel and ignition system.. correct? I dont need anymore than that.. lol
Modified by dr1ftr at 5:54 PM 6/8/2005
All_Motor_KA
Car: 1989 240sx SE
Run the 75 for a while, make sure everything feels tight and fine, then switch it to the 100 shot. Should be fine though as long as your motor is healthy.
