shortys408 wrote:i dont have an amp for them, i think id just run them off the deck for now.
OK, you've got to be joking!
If you already have both of them, then DEFINATELY install the SPZ 60's... I have the Bpston Acoustic Pro 60's installed, and these things kick ***!!!! But, you need a powerful amplifer if you're gonna run either of these....
YOU CAN NOT HOOK THESE DIRECTLY UP TO YOUR FACTORY DECK!!!
these things require between 50 - 150 watts RMS to run, your factory deck (even if you have Bose) is only doing between 10-15 watts RMS at best!
If you are gonna use the factory deck, you would be best served getting a JL audio cleensweep AND a nice high powered 4 channel amplifier... or you can get an aftermarket deck and an amplifier... but I swear if you hook these thing up to your factory deck I will hunt you down and
