Bose system problem
greg13
Car: 1992 maxima se
bose jn1ej01p5nt111876
I have a 1992 Maxima SE with the Bose system.When I turn it on it makes a loud screeching sound.I replaced the stock radio and the proper adapter but no change.I also replaced the alternator and a fiew relays but no change.Any ideas on what to check or how to fix?? Does anyone know where the speaker/ignition relay is? What color? Also clock and lighter work intermittently.Are these all related? Thanks in advance for any help...
dbaxRonin
Car: 2016 Infiniti Q50 Red Sport 400
2010 Infiniti G37x AWD Coupe (Traded in)
2001 Infiniti i30L (Traded in)
If your car has an amp, that would be the next likely suspect. Not sure where it would be in that year/make.
greg13
Car: 1992 maxima se
Each Bose speaker has its own amp As far as I know there is no central one
dbaxRonin
Interesting...initially I was going to post that an amp on each speaker is highly unlikely, but I looked at the 94 FSM and sure enough...it appears as such...very odd configuration and one I have never seen before. How accessible are the amps...are they mounted right to the speaker? My advice would be to find a way to by-pass the amp and just hook the inputs from the amp directly to the speaker as test to see if that resolves the issue. If you can find the relay, that might be worth trying to replace, or you could probably try to by-pass that as well as a temporary test. Looks like the g/w lead (green? gray?) from the head-unit is the switch, and the red lead out of the relay is what triggers the amps to turn on. I can't say how Nissan engineered their system, but typically a remote turn on lead is just a low amp 12v signal so I imagine no harm should come out of trying to hook g/w to red w/o the relay in between. I doubt those little amps are fused though, so do this at your own risk.
Looks like nicoclub doesn't have the 92 FSM, but here is a link to the 94 Electrical section...page 107 has the Bose wiring diagram. I can't imagine it is that much different than your 92 setup.
http://www.nicoclub.com/FSM/Maxima/1994/el.pdf
Good luck!
greg13
Car: 1992 maxima se
Thanks Ill give that a try.The amp and speaker are one unit.Got a used one from the junkyard.Going to replace the one speaker that has no sound and see if that helps...
