Bose System Giving Check Disc Error
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
DanishD
Hi All,
I am fairly new to this forum so kindly bare with me. My infiniti G35 Coupe 2007's bose sound system is giving me problems. It was working fine till last week then suddenly it gave me 'Check Disc' Error. I have tried the following:
1- Disconnected the battery and connected it again. Just incase it needed resetting (NO HELP)
2- Used a CD Lens cleaner (NO HELP)
Can any body kindly tell me if they had the same problem? If yes! then what did you do?
Regards,
-D
audtatious
Yeah, Bose can have some weird issues and this is one. I assume this happens on both burned CD's and "bought" CD's? If so it probably needs replacement or repair. If the vehicle is still under warranty then you can get repaired at the dealership for free. Else, you can look for a replacement or use http://www.shortcircuitrepair.com/
Return to “G35 and G37 Interior, Exterior and Audio”
