Q_SHIP wrote:Return the bass link. I had it and it sucked in the Q's trunk. Get a real sub setup. The Q's trunk is built like a coffin.
This is absolutely true of the trunk in the Q. With the hard metal deck, metal separator between rear seats and trunk, plus the gas tank sitting there... not a whole lot of sound is getting through to the cabin. In fact, unfortunately, the most 'sound pliable' membrane between the trunk and the cabin are the speakers mounted in the rear deck. Thus, you're not only going to get a highly muted version of the sound but may also hear distortion in the speakers in the deck because of it.
Unless you can find an effective way to vent the sub in to the cabin (there are lots of ways to do this, even without using a technically "vented" box) it is unlikely that the sub is going to add significantly to the music you hear.
However... with all that said, it is important to keep in mind that I am talking about pretty small differences in sound based on someone who is specifically listening for such things. For everyday use, and for someone who isn't a real aficionado, you're set up might be just fine.
