Bose Stereo...to replace or not?
Post all your Nissan electronics, car audio and stereo questions here!
ddegarmo
Car: 2001 Nissan Maxima GLE
My "01 Maxima GLE has a bose stereo that is on it's last leg... should I repair or replace any or all of the system?
Thanks
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Better to replace the whole system. My shop can do a CD deck and 4 speakers for around $500 installed. If you did it yourself you could spend less.
Rex
Car: None
ddegarmo wrote:My "01 Maxima GLE has a bose stereo that is on it's last leg... should I repair or replace any or all of the system?
Thanks
How so? Is it the buttons/display, or is the sound quality/volume going?
For most, the factory Bose suffices, but for others they must choose between the total replacement cost and how much sound they want. Good sound quality is not cheap, and a complete re-wire if replacing the Bose will be costly as well.
nchopp
I'm not sure what the Bose system is like in the Maximas, but I know the speakers are somewhat decent in the first gen Qs. I replaced my Bose headunit with a Kenwood and tossed some Infiniti 12s in the back and I'm relatively satisfied - until I have the cheese and time to put in an Infiniti component set. It's the wiring that's the killer. The amped speakers in the Bose system mean the wiring isn't meant to conduct power, so all new wiring has to be run if you want to replace the speakers with anything after-market.
PoorManQ45
nchopp wrote:It's the wiring that's the killer. The amped speakers in the Bose system mean the wiring isn't meant to conduct power, so all new wiring has to be run if you want to replace the speakers with anything after-market.
Not true. You can use the Bose wiring, either the power or signal(i'd use the power), to carry power from an amplifier to the door speakers. It's much easier that way.
Besides, you're more then likely not going to be drawing more then 10 amps through the speaker wires. So they'll be fine
*edit* LOL, I just looked at the date
panther21
Car: 1997 J30
Hey Poorman do you know the wiring guide for the speakers so i could rewire my 97 j30 like the way you talking bout?
