Are you sure that the 2000 I30 had individual amps for each speaker. My 2k maxima didnt. It had a 200 watt bose under the read deck in the trunk and a seperate amp for the sub in the rear deck.MinisterofDOOM wrote:My first guess is that the amp for the sub has died. The bose systems have individual amps for each speaker.
Ah, I could be wrong, then. I assumed the newer Bose systems are like the earlier ones.BOBCAT wrote:Are you sure that the 2000 I30 had individual amps for each speaker. My 2k maxima didnt. It had a 200 watt bose under the read deck in the trunk and a seperate amp for the sub in the rear deck.
I did to but i would still like to get that damn thing to work. I think it will make it sound better.trent.davis23 wrote:I've had a problem in both my old 01 i30 and my 03 i35. It's somehow a problem with the sub itself. I finally gave up and installed an aftermarket sub system.
Are you saying you want to use the factory sub in conjunction with the aftermarket subs?BOBCAT wrote:
It is not in back of your HU. It is under/beside your bose sub in the trunk.McSteve wrote:I heard of someone running their Bose Sub as a center speaker for movies, while having a real subwoofer for the bass. I have no idea how they hooked that up tho. And my bose just died, i thought my rear deck was rattling terribly, but the woofer was just dead lol. So i took it out and dynamatted it all down. 12W6 here i come!
For the amps. From what i've heard they do all have individual amps. I took out my HU and there was no amp under it...
Correct.I am currently using the Bose amp to power the rear speakers in the doors already. I just need to power the sub in the rear deck. I am currently using a Bose amp out of I think a frontier but I don’t think it has the leads out to the sub. I have another Bose amp that I will try and I hope it will work. If not i will have to do some searching on the ORG to find another.trent.davis23 wrote:
