92qatlanta »
https://forums.nicoclub.com/92qatlanta-u40334.html
Sun May 07, 2006 10:28 pm
Thanks to all for their timely and valuable information.
Based on your input, I have come to the following conclusions regarding my 1992 Q45:
- Although I have clear sound with the one rear 1990 speaker installed, the difference in amplification between the 90 and the 91-95 Bose speakers would suggest at a minimum both rears be matched and then adjusted with the fader or not used at all and replaced only with a correct amplification 91-95 Bose speaker.
- After reviewing the recall information, my VIN does fall within the applicable units. I am the second owner and do not know if the rear speaker amplifiers had been replaced. I will assume a recall has no expiration date. I will contact the dealer, inquire if there is any recall repair history for my vehicle, and if not, schedule the repair.
Assuming it goes to the dealer.
Question: Since I already have the rear seat our and speakers exposed from above, would you suggest I leave it apart so they can repair it from above by removing the speakers or should I reassemble everything and let them go in from the trunk. Which would be perceived better to the dealer, or doesn't it really matter?
Thank you.
JTD
