TexRodeo »
https://forums.nicoclub.com/texrodeo-u130352.html
Fri Aug 14, 2009 7:45 am
Only thing is yeah that your deck looks great and I am sure sounds good. But the problem I have still remains, How would I adapt the in-dash plugs from a 1993 J30 to a Newer Nissan/Infiniti Bose Deck as the plugs are very different. I Mean the adapters I have seen or that were pointed Out are not exactly what I need. I have the lil Box already for the Amps as I at Present Have an Aftermarket AIWA AM/FM/CD, model number CDC-X204. What I needed was to adapt the older in-dash plugs to newer Nissan/Infiniti plugs so that I could use an Infiniti/Nissan Bose Deck from 95-Up. I kinda wanted one with the Cassette in a way or an Auxillary out so that I could plug up my XM Radio (Audiovox Xpress-EZ Model: XMCK-5P). The XM-Radio I have is an external one that plugs into the Cigarette lighter and into the Auxillary Out or could use a Cassette adapter or even an FM Adapter which is harder to use, and running an external antenna outside the vehicle to the center roof-line, just above the windshield.
Maybe this Helps...Hopefully.
Larry Little1993 Infiniti J30 White Satin Pearlglow133k miles
