Found this, this is Bose's answer to your questions...
"c. Can I add a subwoofer? No. As noted above, each Bose automotive sound system is completely integrated, with the elements custom-engineered to work together as a whole. If you add a subwoofer to the system, its output is unlikely to be proportionate with that of speakers already in place. In most cases, adding a subwoofer will detract from—not enhance—the sound quality."
3. Can I get a list of technical specifications? "No, because our custom-engineered, complete system solutions largely supersede conventional audio measurements. Even some basic building blocks have been redefined—including amplifiers, speakers and equalizers. But most importantly, our integrated systems deliver results significantly different from those of conventional systems with individual, unmatched components. With a Bose automotive sound system, the location and design of the speakers can be much more important factors in determining output than a wattage power rating. The bottom line? The best way to test a Bose system's sound quality is to use your ears, not a list of specifications. "
This is some bull****, the bose system, as stated earlier, is average at best. If someone stated that the stock amp was 264 watts, it's probably 132 watts rms, averaging about 33watts rms per channel. Even less if they have a five channel setup for the center speaker!
In reality, if you want to add a subwoofer to your system, your best bet is to run seperate power, grounds to the sub. Then, you can get avolume level adjuster like the one I have posted in my Avic D3 write up.
http://www.nicoclub.com/articles.php?id=294580They only cost about $20 and in addition to the normal speaker outs, they also have rear RCA outputs for a subwoofer. Good luck!
